Two bar sensor for my turbo setup, please help w/install!
Just got my 2 bar map sensor and wiring harness. Just need some help hooking this baby up. Not sure exactly where the harness plugs into and where I pick up my vaccum source from?? Thanks guys!
You should just unplug your stock 1bar and the new one should plug right on in as long as you have the new small body map sensor. I know the 3 bars are only made in the larger body but the 2 bars can be bought either way small or big. This link shows the small one http://www.devilsownonline.com/alcoh...products_id=18
Big one http://www.devilsownonline.com/alcoh...products_id=21
If you bought the old style then you should find any source of vaccum with a 1/4" line and tee it off . FWI make sure if you give the map sensor +5 volts and don't apply dirrect power from the battery if your adding one. I have seen quite afew try giving+12v to them and they can't take that.
Map Sensor
