Head bolt torque?
Head bolt torque?
Installed the (10) 15mm bolts per head as instructed (22 ft-#, then 90, 90). Measured the torque after the second 90 & got between 90 & 100 ft-#. Seems OK, but, wanted to check. As mentioned, followed the torque proceedure & measured final torque, just to know. 90 - 100 ft-# seems like where a 22 ft-# then 90, 90 turn might end up & wanted to confirm. Thank-you.
