Best plugs for FI?
Best plugs for FI?
From what I have been reading, it looks like I should ditch the expensive factory double platinum NGKs and replace them with the cheapo V-power TR55 or TR6 plugs. Platinum and iridium are not recommended with FI. Is this correct and how often should the TR55's be replaced? Also, should I alter the OE .060 gap with FI?
http://www.ngk.com/results_app.asp?AAIA=1423886
You shouldnt run platinum for sure... Ive been running the TR6ix (iridium) in my LT1 for quite a while with no problems.
The platinums get too hot, start glowing and melting, causing detonation and/or engine damage.
I always run .030 -.035 gap.
The cheapo V-powers also work well, they just dont last as long.
LS1Tech Co-Founder
5-8 psi? NGK TR6's gapped at .035 would be the ticket. Some might go for .040-.045 to get that little shake out of the idle but you can experiment around.
I run TR8's @ .030 in my current setup.
Originally Posted by fastlt1
What is the part number for the TR6s for LT1? So the auto parts store can look it up.
You can also run
BR7EF
BR6EF
BR7EFS
Probably not enough boost for that.
http://www.ngk.com/search_char.asp?t...=39&action.y=9
