Melling HV & HP oil pump ?
Old 01-15-2006, 06:57 PM
Randy WS6's Avatar
Question Melling HV & HP oil pump ?
Will the Melling HP & HV oil pump work with a double roller timing chain ,I herd there body was thicker than the LS6 pump .I was going to get one for my new 05-LS2 418cid. I have already ordered the new double roller timing chain from ERA Performance and wanted to get the Melling High Pressure & High Volume oil pump But don't know if the Double chain will fit in there , Can any body help me need to order the pump tomorrow if possible
Old 01-15-2006, 09:38 PM
Randy WS6's Avatar
bump up, need help with this
Old 01-30-2006, 04:58 AM
The1N_only's Avatar
Hey did you ever figure out if it would fit?
Old 01-30-2006, 05:32 PM
Randy WS6's Avatar
yes i called them and they said it would not fit with a double roller timing chain because of the thicker oil pump body. it would hit the timing cover with the timing chain shims for the oil pump, espeshaly the LS2's because of the cam sensor placement i went with the LS2 oil pump and shimmed the spring.125" and ported the inlet and outlet and deberd it.
Old 01-30-2006, 07:15 PM
cyphur's Avatar
that sucks man, i run a melling pump and thats a nice piece.
of course, i went with a LS2 timing chain to avoid the clearance issues. thats a beefy sumbitch.
Old 01-30-2006, 07:20 PM
Randy WS6's Avatar
I ordered the double roller for the LS2's for ESP performace ,but it's not came in yet ,been waiting over 2 weeks now hope to get it this week for my engine build 418 aluminum LS2
