Non-Automotive Classifieds - For sale, alpine 9855, pac swi-x, kenwook amp
jimmy 2 Times
01-16-2006, 09:41 AM
i am selling an alpine 9855 ( i have all parts, books, and i even the box.) I will also include a wiring harness, mounting kit, and antenna adapter if you need it (just tell me what car), $300.00
i am selling the pac swi-x for $45.00
also selling kenwood kac 8401 4 ch. amp $115.00
specs
Cast Aluminum Heat Sink: with Sandblast Finish
Power Indicator: Blue Logo Triangle
POWER RATINGS
Bridged Power Output at 14.4V (1kHz, 0.8% THD): 180 Watts x 2
Maximum Output Power (Bridged): 640 Watts
Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 90 Watts x 4
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 60 Watts x 4
AUDIO FEATURES
4, 3, or 2 Channels of Amplification
Ground Isolation Circuit
Input Selector: AB/A (Common)
Quiet Turn-On
RCA Audio Inputs: Gold-Plated
RCA Line Outputs: Gold-Plated
Speaker Connectors: Gold-Plated, Screw-Type
Speaker Level Input Terminals: Plug-Type
Stereo, Left + Right, Mono, or Tri-Mode Operation
Variable High-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave, A and B Channel
Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave, A and B Channel
Bass Boost: Off/+6dB (90Hz)
POWER SUPPLY FEATURES
2-Ohm Stable
Copper EE-Core Power Transformer
Noise Supression Filter: Toroidal
Power Input Terminals: Gold-Plated, Large Screw-Type
Power MOSFET Switching Power Supply
Power Supply Fuse: 40A
Secondary Capacitors: 2
any questions, feel free to pm, or email me
thanks
jimmy
jimmy 2 Times
01-18-2006, 03:02 PM
bump up
lo_jack
01-31-2006, 08:51 PM
Hey do you till have the SWI-X? I pmed ya but got nothin back either way.
