Nitrous Oxide - NX Switch Panel/TPS Wiring
BadAssFast
01-17-2006, 08:28 AM
With the NX switch panel 15896, does the GREEN TPS relay wire connect to Pin 1 "Blue" on the switch panel? Is it providing a 12 volt switched signal to the TPS relay allowing the TPS to turn ON?
NXRICKY
01-17-2006, 11:26 AM
http://www.ls1camaro.net/freehosting/word%20single%20stage%20with%20a%20relay%20and%20T PS%20and%20FPSS.JPG
http://www.nitrousexpress.com/Instructions/switchpanel.pdf
This is not exactly what you were looking for, but the switch panel it only controlls low amps.
Ricky
BadAssFast
01-17-2006, 11:33 AM
Ricky
Actually that's great...my mind is jello right now.
Follow up...
1- The W/S then switches a relay that gives ground to the solenoids
2- The FPSS can be deleted and pin 85 goes straight to ground?
NXRICKY
01-17-2006, 11:54 AM
Follow up...
No your W/S yellow (for MSD) will go to the85pin and the black will go to ground.
The FPSS and or WS controlls the ground side of the relay.
Ricky
BadAssFast
01-17-2006, 12:03 PM
Ricky
My bad...
In essence just swap out the FPSS for WS?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
