motor mount install
motor mount install
welp, i tried doing the drivers side install but i just dont have the rite equipment.
is their anyone else besides fbody motorsports and moreperformance around the charlotte aria that can install motor mounts? i called fbody motorsports and the guy said he had never done this before and he wants to drop the craddle, that doesnt sound too pleasing to me.
who else does motor mount installs and what is the price ill be looking at?
thanks, ryan
thanks, ryan
the right equipment? All you need is some jack stands, and a jack, a rachet, and extensions, or some gear wrenches. so PB blaster, or wd40 will help lossen the bolts.
if you take the headers off, it will be much easier
the thing is my whole y-pipe/catback is welded up and i cant figure out how to get the headers off of the y-pipe. also, its my daily driver pretty much and i have school from 2pm-8:30pm evory day during the week.
Will do,
Where do you reccommend buying the motor and tranny mounts? I found them on thunderracing.com but not sure which ones i really need, id like to get the motor and tranny mounts, let me know thanks!
I drove to Summit to get mine. I needed mine the same day. Speed Inc is good, too. Free shipping on orders over $100. Let us know how the install goes. Especially the passenger side.
What is the part number for the ones at summit?
Motor mounts # -?
Tranny mounts # = ?
Once i get everthing ill let you know how it all goes.
Putting headers, custom catted y pipe, plugs and wires, motor and tranny mounts.
Any helpful links to the install of any of these is appreciated thanks!
Motor mounts # -?
Tranny mounts # = ?
luckly for me, I'm planning on new poly. motor mount/trans mount but, heads/headers will be off cause I'm doing a head/cam swap along w/ headers. so sounds like I should have no problems.
fuerzaws6
fuerzaws6
remove the altenator and starter,then you can get to the long bolts, what is a little hard is lossening the bolt to the engine. use a 15mm gear wrench to make it all easier. remove the frame stands, long extintions and a swivel help to. its frustrating but worth it on the first drive after. it took me about 2.5hrs to do mine and showing a few other how.
