Dyno Numbers from a set of our 195cc 23 Degree heads
Here are some dyno numbers from a customer who built a 350 +.030", 6.00" rods, SRP flat top pistons, Comp 230 int./236 exh. .510"/.520" 110 LSA hydraulic roller, Performer RPM air gap intake, edelbrock card, Patriot 2.02"/1.60"/64cc 195cc runners, Super Street version. Below are the numbers:
RPM Torque HP
4400 446.5 374.1
4600 448.3 392.7
4800 449.3 410.7
5000 448.2 426.7
5200 446.6 442.2
5400 443.2 455.6
5600 437.5 466.5
5800 429.6 474.4
6000 423.4 483.7
6100 420.2 488.0
RPM Torque HP
4400 446.5 374.1
4600 448.3 392.7
4800 449.3 410.7
5000 448.2 426.7
5200 446.6 442.2
5400 443.2 455.6
5600 437.5 466.5
5800 429.6 474.4
6000 423.4 483.7
6100 420.2 488.0
Thank you. Forget to mention that these heads are 100% CNC ported, come with Ferrea valves, our Gold springs, ti retainers, machined locks, screw in studs and guides plate all for only $1295.00 per pair.
Originally Posted by 1fastWS6
Nice Gunnar......what's the compression on that setup? About 11:1?
Originally Posted by Strokinit383
Nice. Id also like to know the comp. ratio. What cam is that? Looks similar to an xe284.
http://store.summitracing.com/defaul...=egnsearch.asp
wow! those are VERY impressive results. is there anyway you could possibly put up the actual dyno chart? i have a hard time visualizing the powerband just by looking at numbers. also i assume this is crank hp correct? im in the middle between a built ls1 and a built sbc for my 3rd gen trans am and this might be enough to push me over the top...
*EDIT* couple more questions. what intake bolt pattern do these have and are they perimeter or center bolt valve covers?
We will try to get a better copy of the dyno chart. The one we have a is not a good copy. We can set you up a set for center bolt and the intake pattern is for a carb intake. This is crank hp.
and ya that graph would be totally awesome! if finances stay good i may pick up a set later this summer.
I am doing a similar build and have been shopping for heads, these look real promising. I have much interest in seeing the dyno graph as well, or at least the power #'s in the lower rpm range.
