General Maintenance & Repairs - belt squeak
delinquent543
01-17-2006, 07:43 PM
when my engine is on and idling, i get this super annoying squeak coming from the engine. im guessing its a belt, but im not sure. idk if i should state more info regarding the nature of the squeak... but thats about it. i dont think that oiling it would be to smart. any one else have this problem? maybe the fact that its 3 degrees out every night, which causes the belt to become ridgid and hard, then when it heats up it squeaks? hmm :)
jimmy 2 Times
01-17-2006, 08:04 PM
maybe your tensioner, or just old belts, and DON"T use "belt dressing"
delinquent543
01-17-2006, 09:59 PM
any fixes?
kodiak
01-18-2006, 02:20 AM
The best fix is this :
http://www.thunderracing.com/catalog/?action=vshop&vid=3&pcid=113
A most excellent resolve to the constant GM tensioner problem!!
I did the same as anyone else , changed belts and tensioners several times before I was turned on to this tensioner ! Also do not forget to order the pulley needed for it ! The pulley is not on the web site , so call and ask !
Mr Incredible
01-19-2006, 08:24 AM
I had that squeal. I changed the idler pully only and it went away. You could remove the plastic seal on the pully and repack the bearings if you want and save the $15.
If that doesn't work it could be the tensioner pulley. I purchased both but only needed the idler pulley.
99FormulaM6
01-19-2006, 08:31 PM
i went to napa and got a new belt. all fixed here. although it was 35 bucks :(
273sunsetZ
01-19-2006, 08:51 PM
I bought the belt, and it hasn't resolved the problem. Last weekend, I took the belt off the idler pulley, and spun the pulley. The bearing was definitly shot, I could hear it. My car is going to be sitting in the parking lot of TTU behind my dorm until the part comes in and I can fix it.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
