Drag Racing Tech
Wheelie bar pics and mounting info needed!
Old 01-17-2006, 08:55 PM
RUQWIKR's Avatar
Default Wheelie bar pics and mounting info needed!
Guys with wheelie bars, can you post up a pic or two and specifics on your bars where they mount to the axle tube? Please note what brand you are using and what you had to do to fit them regarding the swaybar, panhard bar, and clearancing of the t-top well. I've heard quite different stories from folks.
Your help will be appreciated. Thanks and take care. Dave
Old 01-17-2006, 08:59 PM
GIZMO's Avatar
Dave,
What on Earth do you need wheelie bars for? I just purchased a KTRE rear with brackets for wheelie bars on it. I was thinking to cut them off to save weight!
Take Care,
Daren
Old 01-18-2006, 10:06 AM
LS1Tech Sponsor
MADMAN's Avatar
Dave you will have to trim the t-top well. Also the passenger side bars needs to be removed if you let the rearend hang.
Attached Thumbnails Wheelie bar pics and mounting info needed!-f-body-wbars-001.jpg   Wheelie bar pics and mounting info needed!-f-body-wbars-002.jpg   Wheelie bar pics and mounting info needed!-f-body-wbars-003.jpg   Wheelie bar pics and mounting info needed!-f-body-wbars-004.jpg
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-18-2006, 03:30 PM
RUQWIKR's Avatar
Thanks so much...still looking at bringing the car down sometime for the bars and the new full cage. Take care. Dave
Old 01-18-2006, 07:39 PM
So Slow's Avatar
Brian in the first photo did you relocate the panhard rod or is it in the stock location..I've heard you have to lower ? it to clear...Another thing is that your wheelie bar in the pictures or another brand ?
Thanks
Old 01-18-2006, 08:12 PM
LS1Tech Sponsor
MADMAN's Avatar
Thanks
tim that is the same bar that is on Angies car. Which I build. These pics are from another Thunder customer. The panhard is in the stock location.
I hear you might be needing a set soon ??????????
__________________
225-343-9029
Old 01-18-2006, 09:45 PM
So Slow's Avatar
Yes sir..PM sent..Thanks for answering the panhard rod question..
Tim
Old 09-25-2018, 11:18 AM
markieboy's Avatar
I was online looking for directions for wheelie bar install on my 4th gen firebird
In these pictures the brackets that you have on the rear of the housing - did you
have to make them or are they available?
thanks
mark
Quick Reply: Wheelie bar pics and mounting info needed!
