Centermount exhaust on a Z28...yay or nay?
Defintely! there are soooo many other exhaust routes you can take that have been played over and over and over.... CME looks AWESOME IMO. Itd be my #1 choice if I had a camaro. It just looks badass.
I found a fabricated stainless one on ebay. They are available in 2 1/2" and 3" outlets. Definetly stronger than the slp one. Those things crack because they are cast aluminum w/out bracing. Whatever you choose, definetly pimp! A real neck snappin option. Check this out! http://cgi.ebay.com/ebaymotors/CUSTO...QQcmdZViewItem
haw'nz how do you like the kuhmo ecsta supra 712's ? Mine spin... also do you know if the SLP CME tips can be welded back together if they broke in half ? Since they are cast aluminium like you say?
As far as fixing the cme, you would probably have to get someone to specially TIG weld the cast aluminum and it will probably be expensive! I've toyed with the idea of getting an aluminum cme, but I will probably get the 3" stainless steel one . It's a lot easier to fix myself! The cme is 2 1/2". Hope this helps
