qtp off road y pipe
Old 01-18-2006, 06:35 AM
peterock98's Avatar
Default qtp off road y pipe
I'am getting rid of my mac's soon & switching to qtp long tubes.Are there any problems with there off road y pipe or should I go with a custom y-pipe.
Old 01-18-2006, 07:30 AM
slow trap's Avatar
i had alittle hastle with there ory and took it to a muffler shop .they had to cut and re-expand in a couple places and it still hangs alittle lower than i like.for the price i would look elsewhere for the ory but the hvmcs are great !
Old 01-18-2006, 07:58 AM
peterock98's Avatar
I can get a good deal on the price one of the board members has one NIB 4 sale.
Old 01-18-2006, 08:35 AM
LS1LUNATIC's Avatar
I'm with slow trap. After the flowmaster collector there is a cone reducer which in theory is designed well, it just isnt compatible with all exhaust systems. My ory also hangs a bit lower then I wanted but the whole setup together sure does flow good. If you get a professional to install it you will be happy. Just dont try and do it yourself when your car is on ramps/jackstands. PITA!
Old 01-18-2006, 08:45 AM
peterock98's Avatar
I'am gonna install the headers myself and go to mufflex and let them make a custom y pipe then ,there about an hour from my house.I was trying to save a couple of bucks...if it's a pita (the y pipe) I'll let them deal with it.
Old 01-18-2006, 09:35 AM
Durien's Avatar
pete...you'll be fine with the qtp ory... its very nice actually..with their true merge collector.. the mufflex y is actually very similar.. so either way you'll be ok..
Old 01-18-2006, 09:45 AM
peterock98's Avatar
Sent ya a pm....
Old 01-18-2006, 03:57 PM
peterock98's Avatar
ttt up
Old 01-18-2006, 06:44 PM
ssmark165's Avatar
Qtp makes great headers.Go with a custom ory there's will hang to low.
Old 01-19-2006, 03:53 AM
KILLERARMY's Avatar
You need to checkout one of the board member ( SLP9723) set up for a customize Y-Pipe.
Old 01-19-2006, 05:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I think that you should take the clearance thing into consideration...Not saying that you arent, but it will be the part that is a PITA on down the road. literally.
Old 01-19-2006, 06:49 AM
peterock98's Avatar
I tried to search and no member SLP9723.
Old 01-19-2006, 07:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Search is probably jacked at the moment.
Old 01-19-2006, 11:51 AM
peterock98's Avatar
Where is he located?
