Automatic Transmission - Th350
View Full Version : Th350
Crazy Man
01-18-2006, 05:41 PM
Im shure this has been asked before but what are the advantages of using a th350 over a th400 whats the differance? Does the th400 have 4 gears? And what has to be changed to add either tranny.. :drive:
gnx7
01-18-2006, 06:26 PM
TH350 will handle for numbers sake let's say 800hp if built up. It is a 3 speed auto with no overdrive.
A TH400 will handle 1600hp+ if built up properly and is a 3 speed auto with no overdrive. It will also suck up about 30-40hp due to heavier internals (parasitic drag). It also ways probably 50lbs more.
Weight of the vehicle will determine how much abuse a transmission will take. Lighter cars are softer on parts.
4L60E is basically an electronically shifted TH350 with overdrive (but TH350 will be stronger)
4L80E is an electronic TH400 with Overdrive
Powerglide is a 2speed automatic with no overdrive and is usually put in cars with lots of power but limited size tire (non tubbed). They suck up the least amount of power, are the cheapest to build up, and can handle a crap load of power.
Crazy Man
01-18-2006, 08:55 PM
How do you set the shiftpoints on a Th350
john kilgore
01-19-2006, 10:14 AM
b&m sells a gov. weight and spring kit to adjust shift points. pn 20348
Steve Burger
01-19-2006, 11:57 AM
Go full manual valve body and shift yourself.
Crazy Man
01-19-2006, 12:30 PM
Thats a great idea Steve thanks!
ty_ty13
01-19-2006, 12:40 PM
th350 from ATI is the way to go... i got mine built to hold 1000hp
tuff
01-19-2006, 12:43 PM
As said above less rotation mass.I have a manual shift as well and love it.A well built turbo 350 should hold a low 8sec car.I have a turbo 350 and its a great tranny.
Crazy Man
01-19-2006, 07:08 PM
Ill have to go th350 with a manual valve body then. Im planning on shooting a 200shot. So maybe a th350 and a 12bolt with a spool will not blow up right away lol
ty_ty13
01-19-2006, 07:15 PM
i'll warn you th350's usually cost more to build but they are lighter and faster.
