____3000 stall how is it with 306 & 3.73??___
I found used (few 1xxxx kilometers) stall TCI 3000 its opening from 3000 to 3500 as web said. Will be suitable with 306 cam and 3.73
If you are getting some kind of deal go for it. If not, go bigger. I put an SS3600 in last year and love it. I have the Hot cam with 3.73 gears. It will pull the tires off the ground, it hits so hard. Your cam is bigger, but I bet it will feel like mine with the 3000 behind it. It is probably not the absolute best converter for your set up, but it will be a fun car with it in there.
I run a cc306 with a 3500- 3800 TCI super street fighter and a 4.10 gear. It is alot smaller than the old one that I had in the race car (a 5500), but it does feel good when it pulls harder on the big end.
