broken wheel stud
Old 01-19-2006, 01:30 PM
01BlackBirdWS6's Avatar
Question broken wheel stud
I was taking off my wheel and one of my rear wheel studs broke. I heard that all you have to do is hammer it out but its being difficult. Any suggestions? I put some pics of the stud below. Thanks
Old 01-19-2006, 01:42 PM
cablebandit's Avatar
knock the **** out of it...it is just pressed in. Then you will need to remove the abs sensor on that backing plate and it will slide out that hole
Old 01-19-2006, 01:45 PM
ThaLS1KidII's Avatar
When you knock it out just make sure it is lined up with the little divit in the backing plate. It gives you just enough clearance to get the stud out and the new one in. Just buy one or two extra cheepy lug nuts and use a wrench to suck the new stud in.
Old 02-06-2006, 07:20 PM
jmurray87's Avatar
I broke 2 of my front ones today when trying to find out why my caliper is makin a clickin noise when I drive. I guess it goes the same way to replace the front ones.
Old 10-29-2006, 12:31 PM
jbres79's Avatar
i was putting on my winter wheels today and noticed i had two broken studs, one in the back, one in the front. not sure how it happened.
Old 10-29-2006, 01:23 PM
blkbird's Avatar
Just got one of mine replaced. They broke it a Discount tire and they paid to get it fixed. All they did was knock the old one out and pull the new one in place. Didnt take very long.....
Old 10-29-2006, 04:15 PM
2002 Trans Am's Avatar
just knock the bitch out with a hammer.
I've read here to cut part of the new stud into a D shape so that it slides in easier
Old 10-29-2006, 11:17 PM
00 Freak's Avatar
Same thing happen to me. Just knock the crap of it. I used a few washers and got one my lugnuts and pressed in the stud. I got my stud from Advance for less than a dollar.
Old 10-30-2006, 08:44 PM
dsmawd350's Avatar
yeah get a bigger hammer! i just threaded a lugnut on mine and beat them out. Also i put in longer ARP studs for my WELDS and i had to gring a half circle out of the backing plate to get the long *** ARP's in
