FS: Alot of race parts
FS: Alot of race parts NEW PARTS ADDED
Forged shortblock
5.7 alum block
stock crank
crower rods
Lunati pistons for 12.5:1 compression on stock ls1 combustion chamber
rollmaster double timing chain
comp cams lifters
238/242 608/612 on a 114 comp cam
ported ls6 oil pump
ASP pulley
Stock oil pan
ARP head studs
The motor was assembeled by my buddy who works at Reher Morrison, and has roughly 3 hours of run time ( break in, a few dyno pulls n/a, on and off of the trailer)
-$2700
TEA stage 1.5 5.3L heads (installed as long as engine)
--$1400 with stock rockers, manley pushrods,
Race built powerglide all good internals with stock 1.76 gear set. Pro tree transbrake. Aftermarket moroso aluminum fabricated pan.
--$1000
PTC spragless race converter for LS1 with powerglide. 3500 stall.
--$300
17X11 50mm offset ZR1 rim replica
--$225
Fuel System
Aeromotive a1000 pump
" " high flow filter
" " a1000 regulator
Mallory billet fuel rails
28lb injectors of off 98 ls1
5 gallon RCI fuel cell
all AN lines and fittings to install onto f-body( starlight hose and puchlock hose)
-$800
Nitrous kit
Wilson manifolds single stage plate with burst disc
extra burst disc with adjoining tool to replace with
jets for 150 - 375
Big Orfice nitrous solenoid
Big Orfice fuel solenoid
-6an feed line
10 pound bottle
holley blue pump and regulator
Fuel lines to fit f- body for seperate fuel system. (pushlock hose)
All parts are new except bottle. ( fuel system was flowed but never used, bought extra burst disc because one got punch out on accident by a friend)
-$750
Also have a lift off VFN fiberglass 5 inch extended to windshield hood for trans am Ram Air. Has been drilled for dzues fastners on each side.
-$400
Stock computer, harness, and LS1 Edit ( wiring harness has been stripped down getting rid of everything i was not using, which was ALOT)
-$600
GMPP Intake- $250
Accel 4150 throttle body 1200cfm - $400
B&M pro stick shifter for powerglide with cable - $130
Katech Billet tensioner- $100
I was building a racecar but due to funding issues and lack of time to finish the project i am selling my parts. If you have any questions about anything send me a PM. I am open to offers but dont be rediculous. Buyer pays shipping.
5.7 alum block
stock crank
crower rods
comp cams lifters
ported ls6 oil pump
ASP pulley
Stock oil pan
ARP head studs
-$2700
--$1000
--$300
--$225
Fuel System
" " a1000 regulator
-$800
Nitrous kit
jets for 150 - 375
-6an feed line
10 pound bottle
-$750
-$400
-$600
GMPP Intake- $250
Would you sell the following parts seperately?
Fuel System
Fuel System
