wheel spacers, where to get them?
do you realize how small 3mm or 5 mm is? It's in-between 1/8 of an inch...think of it...about the thickness of two credit cards put together.
I don't think you'll ever notice a difference using them. If you are trying to clearance something...grind it to fit. THat is such a small amount!
I've got 1/8" IROC spacers on the rear of mine. You can probably find some pretty cheap. Look on Ebay or try www.thirdgen.org.
Originally Posted by z28_theantirice
Well the reason I was wanting such a small spacer is because I have some 18x10.5 Z06's with a 58mm offset, and so if i were to get a 5mm spacer it would provide a little extra room and less banging on the inner fender well
I believe with those rims, you will need a 1/2 - 3/4 in. spacers
i have the same wheels as you, and same size tire.. customwheelsmarket.com.. 1/4 inch spacers is what you need... go to that site and give them a call.. they might be like ten for the pair i cant remember, but not much
