moser 12 bolt filter???
there anyone who has ever made or bought a filter for the breather hose?Trying to limit the amount of gear oil that leaks out of the breather hose becouse i have the sts turbo and my air filter is back there thanks
Originally Posted by eas020223
moser told me to fill to the plug on the side of the housing not the fill plug on the housing cover. if thats the case mine is over filled
Originally Posted by CTSmechanic
I like to run the oil level where I can barely touch it with my finger
Thanks,
Jim
i used the one on the rearend cover. but from the rear of the car on the right hand sikde there is a plug on the axle housing behind the rear end cover and moser said thats the full plug marker??
I don't use the holes on my moser's TA cover at all.I have them sealed up with silicone as they had a nasty tendency to weep oil.
On the passenger side of the rear center pumpkin there is a fill plug that requires a 9/16" allen head to remove or tighten.With the car level fill the rear with oil till it just starts to come back out of that hole.Install fill plug and tighten.Done.
