A/c?
Old 01-20-2006, 10:19 PM
JSmee99T/A's Avatar
Default A/c?
Is it possible to remove the a/c all together on my ta. Will it help me gain a few hp and if it can be done what do i have to do to make it work?
Old 01-20-2006, 10:23 PM
OOZ28's Avatar
Just take off the A/c belt.
Old 01-20-2006, 10:48 PM
Badls6SS's Avatar
It really will not increase your horesepower but if you remove all the A/C components you can save some weight
Old 01-20-2006, 10:52 PM
JSmee99T/A's Avatar
so thats all the smaller second belt does is power the ac? is it hard to remove all the stuff? what all needs to be taken off?
Old 01-21-2006, 12:00 AM
PewterNHRA2001's Avatar
im looking to do this as well, i have a convt, so not too much need for the a/c haha...however i did hear that it does free up a little hp cuz its not driving the other belt anymore
That's what she said...
TheBlurLS1's Avatar
Yes the smaller belt is for the A/C compressor.
You can just start ripping and tearing everything connected to the system. Lines from compressor to condensor, remove condensor, remove lines from condensor to evaporator (on firewal), remove line from evap back to compressor (this run includes the big aluminum accumulator).
If you want to get really creative, you can remove the evap coil from inside the dash as well. If you can live without the heater, you can remove that entire big black plenum, the heater core, fan motor, hoses, etc. Somebody has a blockoff plate that rivets from the inside of the car and plugs the hole.
It makes changing the #8 plug a snap too
Old 01-21-2006, 12:02 AM
TheBlurLS1's Avatar
It frees up almost no hp due to the compressor having a clutch on the front.
This mod makes for a much cleaner engine bay, easier access for working, and a great weight reduction, which is off the front of the car no less
Old 01-21-2006, 02:22 AM
edwardswb's Avatar
Anybody know how much the AC stuff weighs? I'm lookin forward to ripping mine out
Old 01-21-2006, 11:53 AM
WILWAXU's Avatar
Weight is the only reason to remove it.
Old 01-21-2006, 12:40 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
And to make your next cam swap a breeze.
Old 01-21-2006, 12:41 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is not lightweight. I would have to say around 25 pounds. all parts and everything.
Old 01-21-2006, 01:24 PM
WILWAXU's Avatar
How's that?
Done a few cam swaps.. A/C has never been in the way.
Old 01-21-2006, 02:48 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that hardline that is right there on the radiator. I broke it once because it moved too much to the left. so i found that i was being more careful when A/C was installed. 35$ part. So I would just take it off. So you can do a cam swap without having to recharge the A/C when you are done? That would be pretty cool. I just like having my space. probably for a spring change as well.
Old 01-22-2006, 10:26 PM
JSmee99T/A's Avatar
Good Stuff guys thanks, sucks it doesnt give any hp though the car doesnt get driven in the winter so i really dont need heat...cold nights might be a prob though.
Old 01-23-2006, 02:27 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You mean hot right?
Old 01-23-2006, 09:52 AM
TheBlurLS1's Avatar
You mean hot right?
I swear if i leave the windows up in my car, my own body heat warms the car up before the damn coolant gets up to temp
Old 03-14-2006, 06:21 PM
Bad30th's Avatar
Sorry to dig up this old thread - but quick question...
Is there a need to do something to block the shroud off on the sides after removing the condenser ?
Thinking about pulling out the A/C soon since I can't use it in hot weather without overheating anyway.
Rob (Bad30th)
Old 08-07-2008, 01:21 PM
riskadverse's Avatar
Default Need Help A/C Compressor removal
I took a brief look at the mounting for the a/c on 1999 z28 . I can see a front bolt . There evidently is more than one bolt holding this thing on.
Can someone please list some simple instructions on proper removal of the compressor.
Do you have to drop the stabilizer bar ?
Exactly how many bolts are holding this thing to the block or bracket?
I cant get the car high enough in the air or on lift to see any better. Is it possible to remove the a/c compressor without owning a scissor lift or something?
Any help would be appreciated. I am new to the Ls1tech forum.
I am fully capable of pulling a vacuum, and recharging the system etc..
I just have never seen an LS1 out of the car to see how everything is mounted. My first attempt at removal ended in a retorquing of the one bolt i could see and dropping car back off jackstand...
Someone give me a few pointers here how to remove the compressor. The belt is already off since i used the car to run in the SCCA.
thanks..ric
