Northwest Members WA, OR, ID, MT, WY, SD, ND
The shape of things to come...
Old 01-21-2006, 01:00 AM
CHarris's Avatar
Default The shape of things to come...
This isn't even close to being ready to run... but you can see it's gonna work. Huge progress tonight!
Attached Thumbnails The shape of things to come...-img_2021-small.jpg   The shape of things to come...-img_2020-small.jpg
Old 01-21-2006, 07:13 AM
Steve Goodwin's Avatar
Holy crap Batman.
Have I been asleep when did you start this project??????????
Old 01-21-2006, 10:33 AM
Ackattack1's Avatar
looks like it was made to go in there
Old 01-21-2006, 10:47 AM
CHarris's Avatar
Theres a couple of points that will need a little clearancing... the steering joint and the passenger side of the "k-brace" right at the frame. Otherwise the LQ4 dropped in once II elongated the motor mount frame holes up and out. The Driveshaft will have to be lengthened about an inch and the C-beam extended about an inch but thats the main fab work required. Interestingly, even moving the tranny forward an inch it'll still have more rear weight bias than stock- the LQ4 is just more compact and sits farther back. I'll look again this morning to se if its feasible to just move the engine back the inch, but I think it'll hit firewall clearance issues. I'm not touching the firewall.
It's only taken me two weeks to get to this point... most of that was locating cheap internet parts and waiting for shipping Still need most of the accessories... but I can begin to sell the old accessories now because I know this will work.
Old 01-21-2006, 10:53 AM
CHarris's Avatar
I swear I had wood last night when I stepped away and came back with the camera. It looks perfect sitting there right down to the ZO6 exhaust manifolds.
I'm doing corvette accessories so it will have a lot more clearance between the engine and front crossbrace. It looks like and F-body airfilter can be adapted fairly easily as well. I already have the two piece ZO6 oil pan coming.
Old 01-21-2006, 11:42 AM
Z ANGEL's Avatar
That thing is gonna be sweet!
Old 01-21-2006, 12:36 PM
Ackattack1's Avatar
what tranny are you using?
Old 01-21-2006, 01:41 PM
CHarris's Avatar
It'll have a built 700R4 behind it. I wanted to go 4l65... but there are complications. It it were in any other chassis with a normal trans crossmember it would be a 4L65E.
Old 01-21-2006, 02:01 PM
TwoFast4Lv's Avatar
well cory if the 4l60 does not live we can use a LT1 4L60E in its place and pick up the rest
Old 01-21-2006, 02:27 PM
My1st Truck's Avatar
Wow Cory that looks great!
Old 01-21-2006, 03:31 PM
Slalom4me's Avatar
Did you buy mounts like those offered by S&P or have you fabricated
your own? What are the plans for the exhaust: manifolds or headers?
You can expect a flood of interest in this project from fellow C4 owners.
If you haven't already seen it, there is a fairly extensive thread that
may have some solutions as you move along.
Old 01-21-2006, 03:32 PM
WAHUSKER's Avatar
Damn Cory, get tired of the Hummer already? Looks like a nice fit...
Old 01-21-2006, 09:14 PM
Robert56's Avatar
Very cool.
Robert
Old 01-21-2006, 09:20 PM
Lunchbox01's Avatar
Location: Stationed at NAS Whidbey Island in Northwest WA.
thats hot!!!!
Old 01-21-2006, 09:31 PM
-=Jeff=-'s Avatar
Very COOL!!! I really want to do this but I have a feeling the ZF6 trans will not work in my case..
Old 01-22-2006, 12:24 PM
CHarris's Avatar
I bought the mounts from ebay and they fit between the stock mounts and the block. They are about 1/4" thick and push the stock mounts a coresponding distance from their proper location. I had to elongate the frame mount holes upward and outward to make it fit. Even still the engine is about an inch forward of the transmission bellhousing so I have an issue to work out there- whether to move the engine back or to move the trans forward.
Currently it is sitting in the bay with ZO6 stock manifolds and it is tight but doable. A little grinding and all will be fine. I have a full ZO6 cat and H pipe piece that I'm dying ot find out if it it'll fit or not. If not I can cut and section it until it does.
Bored with the H2? Never... I just need the "backup car" moving, too.
