Pics of 18x10.5 Z06 wheels on a camaro with spacers?
I was just wanting to see how close to the rear fender lip they get with spacers.
Thanks,
Archie
Thanks,
Archie
depends where you get your wheels.. ive heard from several places that you can only get them in a 56mm offset... in that case, get a 1/4 in. spacer... you can get them from customwheelsmarket.com, they also sell the wheels... i would mount a 295/35 for a good fit and they should run almost flush with the side of the car and stick out maybe an inch from the back bumper and you shouldnt have to roll the fenders so look at how much room you have after you get them mounted, and if you lower the car and decide to roll them, dont, have them cut, thatll keep the paint from chipping... youre probably going to have to grind down the bump stops so if you dont have a grinder, any good garage should be able to do it for about 40$.. it only takes about a 1/2 hour of labor...
