Which Tire is best for the Track?
I'm looking at some BF Goodrich G Force T/A Drag Radials 2. Does anyone have these and if so how do they grip on the track? Nittos 555R are another option and I don't want Mickey Thompsons. What woud you guys recommend?
NOTE: I have an extra set of stock 16 inch rims on which they will be put on so thread life is not an issue.
why not mt's the would grip the best. if you are dead freaking set on not running those, i would go with the g force dr's. they just dont make them in the 275 for 17's
BMW ///M Nerd
Stock rear I assume...
Here's my recommendations.
Mickey Thompson DR is better than both the Nitto and BFG. These are STICKY, and I wouldn't recommend them on a 10bolt at the track.
The usual debate, is Nitto v. BFG. The BFG DR is a stickier tire, and much better at the track. I heat them up a little bit, and they grab MINT.
The Nitto DR is going to last longer than the BFG. But you have to heat the **** out of these tires for them to grab nicely. IMO, the Nittos are a little better in the rain, incase you get stuck in it.
FWIW, I've daily driven on BFGs for probably 6 months, and never had an issue. You just have to be more carefull when it's wet out.
My vote, goes to the BFG DR. I feel that its a much better tire at the track. And you might as well go with it seeing as you have an extra set of 16s. And they do come in 275/40/17s, I have a set as well
EDIT: Spanky, you must have meant BGF doesn't offer a 275/16. And you're right, they don't.
