do i need new lifter for FI!!??
ok i will be doing the 317 head and a differnt cam should i replace the lifters and what kind??
also i heard alot of bad things about comp cams lifter!! falling apart and failing on people!! is this true??
search is your friend!this should be in the internals section, but the answer is no,Itd bepend on the springs you were going to run but if your only running comp 918's you dont NEED them.And Comp R lifters have been known to fail,if your nervous about running them just get a new set of stockers.
