orion565
01-23-2006, 02:59 PM
I have a full tank of windshield wiper fluid, but it doesn't spray when I try and use it any help would be appreciated.
sspower
01-23-2006, 03:13 PM
I have the same problem does anyone knwo why?
Mr Incredible
01-23-2006, 04:19 PM
Does your pump motor run when you try to spray? If not, check the pump. If so, check the inlet for obstruction and hoses for hookup and continuity.
Never had this prob but it sounds good to me...:thinker:
Kenafin_02TA
01-24-2006, 03:52 PM
pump I believe is in the top of the tank. The tank is in the front nose of the car basically. Peek down in front of the radiator and you should see the white plastic tank.
