408 Stroker with Boost
Old 01-24-2006, 02:59 PM
UnZFeat'd's Avatar
Default 408 Stroker with Boost
ok so tomorrow, i plan on winning the lottery, and when i do, i wanna look more into forced induction. ive been pokin my nose around the FI threads for a while, and ive been seeing a lot of guys running a 408 stroker with a turbo. im just wondering why the 408 or 402 is so popular. if it is just better to go bigger then why not get a 427? or is it mostly due to cost? I also usually see them with turbo setups, i have only seen or heard of one with a supercharger. can anyone give me a little clarity and insight on why this motor is so popular and why so many folks have it? Thanks
Old 01-24-2006, 03:05 PM
paspar2's Avatar
From what I've gathered, it's the range of the turbo, that a larger engine doesn't always perform as well. And an iron block 408 is thousands cheaper than a 427. Who cares as long as you're hitting 1000+hp.
Old 01-24-2006, 05:11 PM
2000 Tran Zam's Avatar
Heres a video of my 408 with a turbo in case you havent seen it yet.
http://www.cody624.addr.com/my%20videos/Alan-TA.wmv
Dyno graph I believe is in my sig.
Old 01-24-2006, 05:28 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
If you go 400+ ci, you go big on turbo. A small turbo like a 76GTS or so is a restriction more then anything.
Old 01-24-2006, 06:44 PM
LS1Tech Sponsor
Slowhawk's Avatar
A 408 is cheaper to build than a 427.
Old 01-24-2006, 07:30 PM
UnZFeat'd's Avatar
and is there a difference if its a 408 LS2 vs an LS1?
Old 01-24-2006, 08:00 PM
ls2's can only be 402's from what I understand, ls1's can be up to 427 with an iron block I believe.
Quick Reply: 408 Stroker with Boost
