Help, Vibration in rearend
Hey guys,
I have a problem that is really annoying me. I have a vibration coming from the rear of the car. It vibrates mainly when I take it up to about 50 and hold it at a steady speed or when I let out of it when going that speed. I have replaced the tires and wheels to see if that was the cause. But the vibration is still there. It doesn't vibrate as bad when I am getttin into it, mainly when I let out of it. It is kind of a fast vibration that pulses in and out. It is kind of hard to expain. I have also replaced the driveshaft and u-joints. I am puttting d/s rotors on it next weekend to see if it may be a warped rotor. If anyone has any wisdom to share, let me know.
Thanks.
Thanks.
Check out this thread, it may help point you in the right direction.
https://ls1tech.com/forums/showthrea...6&page=1&pp=20
Originally Posted by splack
Hey guys,
Thanks.
Thanks.
I have the same 70-80mph vibration. I noticed it immediately after I had my Moser bolted up. All the bearings and whatnot should be new so I dont think it is that. I read another post on here that says when you do a 12 bolt you will have vibration until you replace your driveshaft also. I had D/S rotors put on at the same time as the rear end so it could be those also. Or, I was thinking that the crappy bolts I got with the relo brackets I used were generic and didnt fit flush in the provided sleves. Not sure if that would cause vibration but I sure can hear them clanking around when I go over bumps. I'm taking the car in next week to do LT's and having them check all this out at the same time.
I have the same problem, with a stock 10bolt (whining like crazy) and aftermarket relocation brackets and LCAs, etc. It is exactly what you are describing and it seems like it is coming from the right rear, i have taken all of the panels out trying to figure out what it is, let me know if you figure it out.
OOOOch!!!!!
Hey guys i herd you are having problems with whinning from rear end, I had the same problem, (/10 of the time according the the performacne shop that hooks me up says its you rear end it was my rear end as well, My started whining then it strted clanking, the splines started to smooth out whcih is waht caused the high pitvh sound, at the track one night i hit it and BAMM! no mre axel.
