found some prostars 15x10 w 5.5 BS
how will these fit is that not enough backspacing i will be running a 275 50 15 drag radial and i do not want it sticking out
With 6.5" bs on my T/A and 275/50s the tire was dead even with the top of the fender. So if you have a Camaro, the 6.5" would stick out past the fender b/c of the way the rear 1/4 panel is. So you'd have 1" sticking out if you have a T/A, and close to 2" if you have a Camaro.
