Roaring from rear
Roaring from rear
My car has 101k miles on it (98 model) and makes a dull roaring kind of sound that is simultaneous with the rotation of the rear wheels. It's not the wheels being out of balanced or the tires (new tires and had them balanced, neither fixed the problem).
Could the axle bearings be the culprit? Would there be anything else that would cause the noise? I'd rather just fix it than try to drown it out by using a little more throttle.
I know you can buy several of the bearings from local auto places, but I think I am just going to buy a kit from Thunder Racing and replace all the bearings.
Thanks for the help
Thanks for the help
My rear is roaring too. It seemed to happen when i first moved my car after i changed over to ZR1 wheels. It was quiet before wheels, then wheels and noise....so i put the stockers back on and it still made noise. Strange coincidince? So, im just enduring it now. Here in a bit im going to get a 9" and forget about the whole damn rear end all together for the life of the car. Im tired dogleg turns under acceleration, and constantly worrying about the rear pipe-bombing.
What the heck did i do? Did muck the brakes up? I went to 100 lb/ft torque on the lugs. Too much? I also get a nice whoop whoop whoop noise at about 35 from the front. Im half way wondering if its just 10bolt noise going up the drivetrain. it only makes the noise in the front at 35ish. At 80mph its smooth, with only rear noise. Pain in the butt.
