Drag Racing Tech
what times for this trap speed?
Old 01-26-2006, 10:36 AM
1999TransamWs6's Avatar
Default what times for this trap speed?
I ran 10.4 @132.5 seems like a high trap speed to me. What do you all think that trap spped is good for?
Old 01-27-2006, 10:24 AM
lisa33's Avatar
Im not the right person to answer (10.21 141.5) but im wery intrested in the answers.
Old 01-27-2006, 10:48 AM
your car is boosted also therefor you will net much higher mph. However nice times
Old 01-27-2006, 11:24 AM
lisa33's Avatar
Yepp and i had a low stall converter that dropped rhe rpm to 4200 after every shift...
9sec here i come....
Old 01-29-2006, 02:19 PM
christophermorales's Avatar
I have run 10.01 @ 133, foot braking on nitrous, with a 1.40 60 ft, automatic trans. What is your 60ft? If it isn't low 1.4's most likely you're chassis setup is off or your car isn't getting full boost till higher in the rpms and is most cases, blower cars will mph high and not ET as good due to a slower 60 ft since you have to wait to get max boost. Solution, get the chassis tuned, IE. Make sure your instant center is set up right and you have the right shock settings and spring rates, or try leaving at a higher rpm.
