Just got my exhaust now i need some help
Does anybody have a step by step install guide for putting an SLP Loudmouth I on a 2002 Z28?
Please any other suggestions ar aids would be helpful as well.
That's what she said...
Unbolt the I pipe (part that runs beside the driveshaft) from the y-pipe, unbolt the exhaust from the rear hangers, or the hangers from the car if you have to.
The stock I pipe going over the axle might have to be cut to be removed. Mine was welded to flowmaster on one side when i got the car, and had no slip joints. Die grinder with a cutoff wheel made short work of it though.
New exhaust should have a slip joint where the I pipe goes over the axle. Its a very simple install.
Get the car as high as you possibly can off the ground and start taking **** apart.
