I love Pro Stars
fronts are 15x3
rear are 15x10 and i think 7ish backspacing
tires are 28x10.5x15
If i cant get them to not rub bumper/ground effect using the adj. LCAs , I will go to a shorter slick but i think i can make it not rub
Thanks for the compliments!!!!! I have considered getting another pair for the rear and put regular street tires on them for a daily driver but my car is heavy and i worry they will get damaged using them everyday
Originally Posted by tboysen00
so its not lowerd? did you have to grind allot or was it not that big of a deal? thanks troy
thanks a lot guys!! 24" tires on the front....hals adjusting height gives it that stance PLUS it was facing downhill. I had to grind the **** out of the fronts!!!! A lot on the rear too but it was worth it....not at the time but from the next day forward it was
here is how it looks raked the OTHER way
Restricted User
24" fronts look good. I was running the 26 or 27" but they fill up the front, always scared they'd smack on the way down, but they didnt.. I might look for some 25" for the Bogarts that are on the way since the 24" look so nice. BTW, I used to run ProStars daily for a while, not as heavy as your car, but the roads here suck. Only issue was one time I hit a very nasty pothole and it felt like the wheel went out of round. After dismount, remount, the vibes were gone.
