Cutting down ARP Long Studs
1 Post
Hey guys, has anyone done this? I would pressume just use my cut off wheel. I am needing to do this, cuz they are a tad longer than the OEM ones, and I noticed as I was using the torque wrench mounting the new rims, the studs were poking, or atleast crakcing the tips of the lugs!!! Get back with me on your opinion of what to do thanks!! Only need to trim like .250" off...
Put an old open-ended lugnut on there with however many washers it takes to space it to where you want them cut. Repeat that on each stud. That's what I had to do to the 2" spacers between the rear tires on my Dodge dually.
