WTB: Stock Ls1 engine/ M6Trans w/ everything
Hey.....i love my 96 body style and would like to keep it. But when the motor goes somewhere in the next 80,000 miles, i would like to upgrade the power plant in this beast. But it NEEDS to be an M6 Ls1. I would like it to be stock. But show me what you guys got. I don't need a WHOLE car. Engine/Trans ONLY.
I just may upgrade to the digital guages of a 97. Show me what you guys got!
I have a LS1 that needs two new coil packs, passenger side coil pack bracket, passanger side valve cover, and a power steering pump. Has 115K miles on it. Has the wire harness, but the last foot or so had to be cut to be removed, but it's color coded so splicing will be easy.
T-56 with 40K miles on it. it will be missing the reverse sensor. Needs a new clutch.
thx,
I have a complete 2000 camaro motor, the motor has 2,500 miles Brand new long block t-56 tranny, computer, and engine harness. It came out of a 60,000 mile car. The motor is complete from intake to oil pan comes with ac compressor, alternator, water pump, crank pulley, throttle body and asp pulley. The pcm and wiring harness is in complete condition and perfect shape. I am not exactly sure what to ask on it but will start at $5,500 going 408
I have a stock c5 ls1 longblock sitting at MTI in houston. Letting go fo 2500 heads cams and all stock from the c5. Will be inspected and cared for by them. Only 15k on the motor when it was taken out. Was in excellent shape. Got a 427 and TT for the vette. Let me know 4045783913.
You can call david at mti to inquire about the validity of the motor and have it inspected.2818700797 Came out of an 01 vette
