Gears & Axles - Chewing up c-clips like bubble gum.
LC2nLS6
02-02-2006, 11:13 AM
So my Turbo Buick rearend (the good kind of 10 bolt) is wearing out the c-clip on the passenger side. The axle grooves itself pretty good into it after a few hard passes at the track. Anyone else experience this? I've just been replacing them as needed.
bottlefedz28
02-02-2006, 11:43 AM
I would say it's time to put a set of c-clip elims. on the car. The problem could be that the end play, even with new c=clips, is causing the added wear.
What do you mean it is wearing it out ? Is the c-clip wearing on the OD, ID, or one fo the faces ?
LC2nLS6
02-02-2006, 01:36 PM
The c-clip itself is getting metal removed from it's face by the axle. Sorry I forgot to mention that it is only on the outside side of the c-clip (facing the passenger tire).
The c-clip should fit into a radial groove on the axle and into a face groove on the side gear. There should be no relative rotational movement between the axle (and attached c-clip) and the face of the side gear on the diff. I don't understand how it could be wearing ????
Pics ??
LC2nLS6
02-02-2006, 05:31 PM
Pics ??
As the axle rotates, I'm guessing that the axle is digging into the c-clip as best as I can tell. I've thrown my old clips away unfortunately, no pics.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
