HELP! what slicks and drag wheels?
i know nothing about them :wall:
ok im gonna run a 15" wheel (have to grind i know)
the car is lowered
i assume i can only run a 26" tall tire.
what slicks do yall recomend?
i was looking at et streets
i see
26'' x 10.5'' - 15''LT
and
26'' x 11.5'' - 15''LT
can i fit the 11.5 on a lowered car?
what size wheels? what offset?
what drag wheels are the lightest or most popular?
also
what about the fronts i want to run skinnys on drags, maybe a 3 or 4" rim? what offset? will i need spacers? what size tire?
the car is lowered
i see
and
also
Originally Posted by lsevenl
yes, I have a 26x11.50 on my car with bmr springs in the rear. Here is a pic
http://www.stang.cc/tmcaalbums/album27/DSC_0098.jpg
do you have 6.5 or 7.5 backspacing?
the bmr are only 1" right?
did u roll your lips and beat in the inner fenders? (i had to do this for my 18s with 295s....)
also ive been told ill run out of gear with the 4.10 and 26s and should run 28s and that lots of lowered guys are running them, they just require more clearancing.....
Originally Posted by STANG KILLA SS 2
can i stuff the 11.5 under a lower car
what backspacing?
what backspacing?
what are the specs for ur front wheels ? what tire profile ?
thank you,
I'm planning to run 26x11.5 on a 15x8.5 5"bs Convo Pro. My car is lowered with the Eibach Pro-Kit and I've got 4.11 gears (8.8" Hybrid).
Does this sound like a bad idea for some reason?
Originally Posted by OOOJOHN
Im going to put an 11.5 inch tire ( quick time pro) on my 8 inch rim. its a 5.5 inch backspace. If your asking what tire I vote hoosiers. I had et streets and they dont hook on the street. They hook good on the track though.
This is the exact question I'm looking to have answered. I have the eibach kit, 4.10's, and plan to run 15x8" rims in the back with a 26" tall tire. Can I fit the 11.5 or should I play it safe and go with 10.5? Is a 5.5" backspace good enough for either?
