T56 vs Viper 6 speed
I don't think it is really the same transmission. I mean to say they similar and share some parts. It seems like it has a different gear box, though.
I found this at the following link, http://www.vipercompetitioncoupe.com...ications.html# :
Gear Ratios
1st ..... 2.66
2nd ..... 1.78
3rd ..... 1.30
4th ..... 1.00
5th ..... 0.74
6th ..... 0.50
Gear Ratios
1st ..... 2.66
2nd ..... 1.78
3rd ..... 1.30
4th ..... 1.00
5th ..... 0.74
6th ..... 0.50
I bought a Viper trans. for my 71 Chevelle. The shifter is forward more, so I can use the stock consol. (as told by D&D) Thay also recommended using a Viper trans because all the mods they due to the Camaro/Firebird trans. is already done. They claim it should hold up well to my twin turbo LS1 making 750-850hp @ the flywheel.
The pree 03 Vipers had essentially the same gears/ internals as an Fcar. Major dif was in the iron 3/4 fork from the factory.The 03-later units do have dif gears although the ratios are the same. The VIPER bell to block pattern is different( obviously) and the bell to T56 adapter pattern is a little off but useable.The "swap" will also require an input shaft change as well as a clutch release system rework.
