F13 Graphs
F13 Graphs
Since the search isn't fully functional, would those of you who have graphs of your F13 dyno please post them. I'm doing a comparison of sorts and would appreciate any dyno data you all could provide.
Thanks Much!
Josh
Thanks Much!
Josh
Generally an F13 will make about the same power as an LG G5X2. They are very similar in terms of peak numbers, and curves. The X2 may have a bit more up top, whereas the F13 is a bit more torquey. So if you find an X2 graph, the F13 will compare fairly nicely with that. Hope that helps.
Im going with a F13, what kind of power and streetability differences between 114 and 112? Id like to throw a 112 in there, but this is my DD, and I had a 112 in my TA, the surging didnt really bother me if thats the only complaint, I dont know why people whine about surging. But if the power is similar, then Ill just go with a 114.
I went to a dyno day yesterday and the best it pulled was 377rwhp/351rwtq SAE on a dynojet. This was untuned with Pacesetter heads/TSP Catted Y-Pipe to Magnaflow cat back. Ported throttle-body and ASP pulley. Through 3.42's and stock 10 bolt.
I still need to mess with some timing and adjust the A/F a bit. I'm thinking I can get it up near 390rwhp. No dyno graph cause they printed out the graph only going up to 6,000 RPM. Having them send me a new file.
Hey if I have a set of TEA stage 3 5.3L heads and drop a 112 F13 in there what would you expect to see out of that setup? Mods are in sig
I dont know, a lot of heads flow within a few CFM of each other, I should have that cam in with my PP stg 2 heads next week or so, Ill let you know what I throw down, should be 420 minimum with a good tune, hopefully more. I have LT's though which are a little better than midlengths.
I have no dyno numbers for you, but I do have some track times. F13 112+2 with off the shelf Patriot LS6 Style 64cc Heads. Raceweight of 3650lbs and a DA of +500 the car went 11.52@121.5 1.68 60' That right their shows you the potential of this cam with some weight reduction, low 11's easily.
my raceweight will be 3280 or so now that I removed my stereo set up, and with the F13 I should be able to put down another 20-25 rwhp or so.
