80mm TB on a stock motor
Old 02-04-2006, 10:50 AM
Frosty's Avatar
Default 80mm TB on a stock motor
I've tried searching but couldn't find a damn thing.
Mods are in my sig, with a FTRA on its way.
Would a 80mm TB really help me much?
Old 02-04-2006, 02:57 PM
WILWAXU's Avatar
I would wait till you are ready to upgrade the manifold too (i.e. FAST)
Old 02-04-2006, 03:01 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You would be better off porting your stocker for starters, and then getting the 80mm after you get an intake. or even get the 90.
Old 02-04-2006, 03:10 PM
8banger's Avatar
Honestly, you might even lose power with an 80mm. You're only going the get the best out of a mod if your motor needs it. If you car needs more intake airflow, great, but you're still running a motor that was designed to work with the stock 75mm throttle body. I wouldn't get that or even port the stock one until you got full exhaust.
Old 02-04-2006, 03:34 PM
Frosty's Avatar
I have a ported TB now. I was just curious if there was any benefits since I would get a BBK 80mm faily cheap.
I guess it's not really worth it.
8banger, check my sig I already have a full exhaust
Thanks!
Old 02-04-2006, 04:08 PM
8banger's Avatar
Thanks!
Went right over my head, sorry, it was a long night last night. Haha...honestly, it would probably get you maybe 3-5 extra rwhp. It's up to you.
Old 02-04-2006, 04:21 PM
H8 LUZN's Avatar
the only thing a TB does is restrict airflow. Once you reach an unmeasureable pressure drop across the TB there will be no benefit from going larger.
When you do go larger, the throtlle response will be different because you are changing the restriction profile.. i.e. it will reach the minimum pressure drop prior to being wide open... so in essence, your car will be at WOT sooner and the last bit of pedal travel doesnt do much..
Old 02-05-2006, 04:50 PM
tboysen00's Avatar
if i have a ls6 intake, headers, cam will a 80 or 90 tb help me at all, also which size will work better for me. thanks troy
Old 02-05-2006, 10:47 PM
8banger's Avatar
With a cam only, 80 will be better. Get heads and a 90 will be awesome.
