pacesetter long tubes?
i recently bought a set of pacesetter long tubes for my 2000 ta. i was looking online and it said i would have to lift my motor 3in just to get the passenger side on is this true? are there any other ways to put them on?
Your gonna have to get the car a pretty good ways up off the ground, and slide them in from the bottom. I put my car up on jackstands all the way around so I had room to work under the car.
the instructions that came with the headers tell you that you might have to raise the block.. tsp told me you didnt have to, and i didnt.. they also said pacesetter made a revision on their long tubes so you didnt have to notch the k member or anything
Originally Posted by slt200mph
Yes.. I know another guy that had to use the "Polish Method" to install them too...
Originally Posted by akZ28
just jack the car up as high as you can, remove the coil packs, and get your self a 24pack and some ratcheting wrenches. you'll be good.
I did mine by myself with practically no tools and I am
57 yrs old I cut that tab off the drivers side engine block
with a sawzall took about 5 min. to remove it. The install
took about 2 days and and the y pipe wasn't easy but you
will probably do it alot faster than me
mine slipped right in, it was A LOT easier than i thought it would be and this comin from a 17 yr old with not much experiance, the catted y pipe was a PITA tho
Mine was easy. Having a second set of hands is EXTREMELY helpfull, but no grinding or unnecessary trouble here. And 98z28chevy, check your PM's b/c I'm getting rid of my TSP catted Y and pacesetter LT's.
pacesetters are one of the easiest longtubes to install. Especially if you go with the off road headers! It took me and a buddy only maybe 2-3hrs. Of course i was in the middle of a clutch swap also so i had my stock cat-back already off. Its very easy to do yourself.........just grab a friend and some beer!
Brent
Brent
