Engine Diagnostics Code
LS1Tech Administrator
Received 1,486 Likes
P1514 = Throttle Body Performance
Is this a V6 car?
Originally Posted by Helms Service Manual
PCM detects that the actual airflow (MAF) and Speed Density is much more than expected (calculated) air flow rate
Originally Posted by orangeapeel
Is it a sensor that can go bad in there?
www.gearchatter.com
I couldn't cut-and-paste the info, so here is a link that may be helpful:
http://gearchatter.com/viewtopic1030...3c98e4bfbdab9c
Originally Posted by KillerWS6
The actual description of the P1514 is:
"Manf Cntrl Veh.Spd. Idle Speed Control Auxilliary Inputs"
Do you have an idle or throttle response problem?
