HELP!Good pedal pressure but can't shift into any gear from a stop.
I did a search but did not find anything I was looking for, Can some one help me out and tell me whats wrong? My car just started doing this and It's starting to get worst. Double clutching does not work at all, I have good pedal pressure like before but can't shift into any gear from a stop, I also have to shut the car off be for I can shift the transmition into any gear, my shifting feels notchy when It starts to do this. I have no issues with the pedal sticking to the floor when I go wot eather, I dont have much play at the upper end of the pedal and have pressure on the pedal all the way to the floor but one thing I noticed was that when I let off about two inches off the floor on the pedal the clutch starts grabbing a little. Doing this seems to make the transmition want to go into gear more. sorry this is soo long but does anyone know whats going on? thanks in advance.
Originally Posted by SPEEDYws6
When you put the car in gear with the engine off and then crank it does the car start moving? If not, with the car in 1st where in the pedal travel does the car start moving?
I think your pilot bearing may have taken a **** on you. Check one more thing... Put the car in 1st and rev it up to 5k or so and see if the car lurks forward. If the car lurks forward its the clutch, if it doesn't its the pilot bearing. If your going to change the clutch it's always a good idea to change the pilot bearing while your in there regardless of if it's bad or not.
this just happened to me,..
see my post with Pic of Broken PP.
