General Maintenance & Repairs - Ses Light
TOTL-SS
02-05-2006, 02:18 PM
Guys ... I need your help. I want to know why my SES light is always on. I've had this light since I added a set of headers, high flow cats, and GMMG exhaust system. Any idea how I can get rid of it? I've had my car checked out and everything appears to be fine except for the light constantly staying on. :confused:
2001NBMZ28
02-05-2006, 03:11 PM
You need to get the code(s) scanned and then post them, along with some more info on your car (year, other mods, etc.).
orangeapeel
02-05-2006, 03:30 PM
I am willing to bet that 1 or 2 of the codes is a 135 or a 155...I think that you have a bad connection with an 02 sensor or you have a bad one. Are you running simms? Are these longtube headers?
orangeapeel
02-05-2006, 03:36 PM
P0130 (M) 1/1 O2 Sensor Heater Circuit Malfunction Oxygen sensor heater element malfunction.
P0131 (M) 1/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0133 (M) 1/1 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0134 (M) 1/1 O2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor input.
P0135 (M) 1/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0136 (M) 1/2 O2 Sensor Heater Circuit Malfunction Oxygen sensor heater element malfunction.
P0137 (M) 1/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0138 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0139 (M) 1/2 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0140 (M) 1/2 O2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0141 (M) 1/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0143 (M) 1/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0144 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0145 (M) 1/2 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0146 (M) 1/2 O2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0147 (M) 1/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0151 (M) 2/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0152 (M) 2/1 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0153 (M) 2/1 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0154 (M) 2/1 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0155 (M) 2/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0157 (M) 2/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0158 (M) 2/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0159 2/2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0160 (M) 2/2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
RPM WS6
02-05-2006, 03:38 PM
Who checked the car out?
If it was a shop they should have scanned the PCM and told you what code you were getting to cause the SES light.....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
