Conversions & Hybrids - LS1 into 37 Ford "What is needed!"
LS37 Ford
02-05-2006, 07:55 PM
I just remove the engine and tranny from a 2000 Firebird Formula. This will be my donner engine for the 37 Ford. Will I have to change the front brackets and pulleys? What about the cooling issues, headers,wiring,motor mounts? What should I do to the engine and trans. before installing? I am new to this and I am a big fan of learning from others rather than the school of hard knocks! Any help would be appreciated! I am trying to have this car done by Goodguys this summer! PLEASE HELP! What comes first!
55chevy
02-06-2006, 08:32 AM
You may want to check out the FAQ sticky post at the top of the forum.
A forum member "Oscar Will" has a 35 ford with a LS1 and made this post in the FAQ: "You people with old car hybrids and straight frame rails can use the Corvette cast aluminum motor mount brackets with the stock oil-filled mount cushions. The cost is not ridiculous and the set-up works very well."
Also, S&P http://www.hotrodlane.cc/ has a project section listing a '39.
Hope this helps.
Steve
RFERG43
02-06-2006, 03:50 PM
Hope you will post pics when it is done 1
LS37 Ford
02-06-2006, 07:25 PM
Thanks for the info. Where is the best place to get the Corvette mounts? Dealer? or is there some aftermarket cheaper?
LS37 Ford
Sure thing! Can't wait!
jimmyp
02-06-2006, 07:34 PM
ebay will be your friend for conversion parts
LS37 Ford
02-06-2006, 07:38 PM
What years fit? Do you know part #s?
Oscar Will
02-07-2006, 06:48 PM
Ok, here are your numbers;
2 engine mounts P/N 10284134 list price is $80 each
1 10260643 bracket $75
1 10260642 bracket $75
LS37 Ford
02-07-2006, 06:50 PM
Did you use this set up on your car?
Oscar Will
02-08-2006, 11:18 AM
Yes, I Emailed a few photos to you.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
