Anyone familiar w/ the installation process of brakes and rotors?
I just got some new brakes and rotors in, and could use some advice/help installing them. I've heard it's pretty easy to install them on the C5s, but it's good to have someone who's done it before to help you out. With that in mind, I'm not too worried about just going on and doing them, but would rather not take the chance on forgetting something small that would make a big difference. Thanks in advance guys. :thumbs:
Just for reference, these will be going on:
Originally Posted by tru_ice
WOW, nobody?
As for me, I have never done brakes so I would hate to screw up your car.
Rotors and pads are really easy to do... the only special tool you need really is a C-clamp for pushing the brake caliper piston back so its flush with the caliper again. It pushes out as you get less and less material on your brake pads. If you're still on the stock brakes and have never changed them, the pistons probably will have to be pushed back in to get your new pads to fit.
After you get your new stuff on, then you'll want to bleed the brakes. That is fairly tedious, and is much easier with a person to help push the brake pedal while you loosen the bleeder screw. Just make sure while you're bleeding that you keep the reservoir full of fluid, because you do not want the master cylinder to run dry.
Nate
Originally Posted by Nate_Taufer
Ditto...it's about as straight forward as you can get. Just unbolt the caliper bolts. I think they're 12mm. Then the caliper assembly comes up, the rotor slides off and the new one goes on.
Nate
Nate
You don't have to rebleed the brakes if you don't want to if you are just doing pads.. Pretty much Tranzor summed it up pretty good. Basically take caliper off, push pistons in, take rotor off, put new rotor on, put new pads in and reinstall caliper.. Dual pistons can be a little tricky, so have a piece of wood that you can put over both pistons to push them both flush.
If you want to do a good job you need to add the following. Pull the caliper pin's out and clean them and inspect them for wear. Same for the place the Pad's ride. If they are worn they will need replaced.
If every thing is good then you will want to re-grease them with High temp grease for Brakes.
This step will make sure your brakes wear even and are as quiet as they will get.
Many people skip or are not even aware of this step. It can cause many issues
Good luck man!
Good luck man!
Well at least it seems I'm not alone. 45 views, and only 3 ppl w/ some helpful advice. Thanks guys.
Good luck man!
Good luck man!
Dude breaks are the easiest thing you can do on a 4 wheel disc brake car even if you have to bleed them. I would be willing to help one afternoon if you have never done them. I hated doing the drums on my 71 K-5 that sucked!
I want to reiterate what Ellis said about the pin...Clean them, grease them, maybe just replace. I lost a Front rotor, caliper and bracket on my 98 Z28 due to bad pin.
Originally Posted by Poik
Yeah about what Ellis said, Volvo makes some good pink brake grease.
Go Seahawks!!!!
Originally Posted by 00Vette
Sorry bro, I don't know **** about putting brakes on. I aint gonna act like I do!
Have you even got that damn LSX intake and TB on yet? What about the cylinder heads?
