used LT1 moser 12 bolt, into '02 LS1!?!?
I bought a used Moser 12 bolt that was in a '97 Z28, this rear was originally in an '02 SS! (so things were changed)
it is correct 4 channel. ( I do have ABS/TC)
I found today the the brake brackets won't work, and the reluctor ring is different. 47 teeth on my stocker, 53 on the 12 bolt axles.
what do I need to make this work? is the inside diameter of my stock reluctor ring that same, so I can just re-use them on the 12 bolt?
and can I just call moser for the right parts to make it work with my stock brakes?
thanks for any help!
