Anyone Dyno A 370 With Forge Internals
Just Wanted To Know If Anyone Has A Dyno On 6.0 Bored .30 Over. This Is My Set Up Im Finishing Putting Together This Week And Would Like To Know A General Idea On The H.p Anyone Thinks It Would Push.
6.0 Bored .30 Fully Forged Bottom End Diamond Pistions Eagle Rods Stock 6.0 Crank. Magic Stick 3 Cam 610 Lift,patriot Stage 3 Heads, Ls6 Intake, Bbk T.b. Ac Delco 38# Injectors, Slp Underdrive Pully PACESETTER LONG TUBES AND Y PIPE
That Sums Most Of My Mods Up. Anyone Can Help It Would Be Greatly Appreciated Thanks
mine only put down 405/406 with a 228/232 cam about .580's lift. Also my compression is at about 9:1, so that took away some of the hp. But yeah, my numbers are kinda low, but the blower should more than make up for that.
we built a 370ci longblock that originally dynoed 465rwhp(give or take 2 or 3 hp) I forget the torque. once is was broken in and fine tuned it put down 490ish. it was in a C5 corvette.
how much was it to get a 6.0 short block? im budgeting to build a forged 347 with stock crank, eagle rods and diamond pistons, but if i can get a 6L for cheap then i might do that...thanks for the help
jon
jon
Sounds like a sweet setup, and I say you will see about 460-480 rwhp, however you would see even more if you ditch the pacesetters and go with some 1 7/8 headers as you will need it with the bigger CI and that MS3. Let us know though when you get it dynoed and what it puts down NA and on the N2O
my stroker 370 was built 6 years ago (346 block). Wiseco pistons, Lunati rods, and Scat 3.90" crank. .523/.530 lift, 114 lsa, 216/220 duration. Old school heads. Makes about 400 hp and 410. awesome tq curve:
http://207.127.219.37/images/rxdyno2.jpg
I have a guy here in town that gets 6.0 blocks out of newer gmc lq4 and some lq9s paid $400.00 for the block has 8,000 miles on it took it paid 150 to get get bored and put new cam bearings in it.
Mine ran 6.7s @ 103 in the eighth last year with a race weight of about 4000 pounds with me in the car. Since then we added a 9 bolt rearend with a Detroit Locker differential with 3.90 gears and added a second stage of nitrous. I'm expecting to see 6.5s this year.
hey man. just curious if u ever got your car on the dyno. I am goin to be running the same set up only with the MS4 and 42# injectors. Also my cars a 6 spd. Let me know what kind of numbers yours made.
-Blaze
-Blaze
