help me price some parts
At a swap meet.... what would you expect to see for a price? what would you offer?
i'm trying to come up with prices for parts for the swap meet this weekend... i've looked in the f/s & wanted sections & have an idea on some parts, & i've even looked some up on ebay. but i want more input. since i haven't been into f-bodies for years i really don't know what some parts may be worth.
please go through the list below (i know it's incomplete) and give me an idea of what you think i should ask for the parts.
I am not tying to sell them on here. just looking for input & help. if you have questions about them that may change the values please ask & i'll try to answer.
if some parts do not sell at the swap meet then i may later post them on the f/s board here, but for now please don't ask. that is NOT the purpose of this post.
99 Camaro Z-28, (car was sky blue with a grey cloth interior) 112K miles, had LS1/A4.
hood (had some bondo work)
front bumper assy
rear bumper assy
drivers door (includes glass, latch, but not lock or door panel) manual windows, etc.
Left side skirt
Hatch
Wheels-16" chrome 5-spokes, a couple dings & mild curb rash on one.
carpet, grey needs cleaning.
most interior trim pieces (grey)
drivers door panel (manual)
door/hatch seals
both airbags & sensor
steering column w/ key
steering wheel
instrument panel w/o clear cover (was cracked)
drivers seat, fair condition.
rear seat, fair cond.
seatbelts
HVAC unit
A/C compressor/lines/condenser
PS pump, rack & pinion
Radiator & fans
Brake mater cylinder & booster
ABS motor assembly
Headlights
Tail lights w/ wire harness
Tail light center section
Driveshaft- (Al)
Rear axle (complete w/ brakes, LCA’s, shocks & wiring) stock 10-bolt?
Rear springs
Fuel tank- plastic w/ pump
Trans x-member
LS1 K-member
KYB adjustable front struts w/ springs
Front control arms w/ spindles & hubs
Torque arm
Headlight switch
Door & hatch Lock set w/ key
Manual Hatch latch assy
Hatch struts
Hood struts
wiper motor w/all arms/rods, etc.
Stereo amp
Air pump (smog pump)
Hood release cable
Dome light
'spintech' catback
sway bars
’96 Firbird Formula- had a lt1/A4, 121k Dk green w/ tan & grey interior
Hatch w/ low-rise fin
Hatch struts
Passenger door w/ window (pwr)
Rear axle housing w/ open carrier & gears
One LCA
Fuel tank w/ pump assy, metal tank
Torque arm
Trans cross-member
K-member for LT1
Stock front struts/springs
Front upper/lower A-arms, spindles & hubs
Brake master cyl & booster
ABS motors w/ traction control
ABS/trac control module
Radiator w/ fans
A/C condenser
HVAC assembly
Hood latch w/ bracket
wiper motor w/ arms, pivots, & all rods, etc.
Hood release cable
Bumper (steel part)
Door panels- tan & grey
Window/lock switches for door panels
Steering column w/ key
Steering wheel (radio controls)
Upper Dash(grey) w/ both airbags & sensor, radio trim, instrument trim, & HL switch trim. Great condition.
Lower dash pads
Console(auto)
Seats- front & rear, tan leather, power. Drivers has some tears all others are great.
Interior trim panels-tan
seat belts
Carpet- tan. just cleaned but had some remaining stains.
Stereo amp
Stock CD player
E-brake lever
Shifter ****
Door & hatch seals
Tail light- right
Center piece for tail lights (black- no decal)
Tail light wiring harness
Locks w/ key (doors & hatch)
Hatch latch –pwr
sway bars
I know the list is not complete, i just put it together off the top of my head.
If you can take the time to help me out I really appreciate it!!!!
front bumper assy
rear bumper assy
Left side skirt
Hatch
door/hatch seals
steering wheel
seatbelts
HVAC unit
Radiator & fans
ABS motor assembly
Headlights
Driveshaft- (Al)
Rear springs
Trans x-member
LS1 K-member
Torque arm
Headlight switch
Hatch struts
Hood struts
Stereo amp
Hood release cable
Dome light
'spintech' catback
sway bars
Hatch struts
One LCA
Torque arm
Trans cross-member
K-member for LT1
Radiator w/ fans
A/C condenser
HVAC assembly
Hood release cable
Bumper (steel part)
Lower dash pads
Console(auto)
seat belts
Stereo amp
Stock CD player
E-brake lever
Shifter ****
Door & hatch seals
Tail light- right
Hatch latch –pwr
sway bars
I know this is way off topic...
But did both of you buy F-Bodys, wreck them, and are now swapping the motors into RX-7's? Or am I just being crazy, nothing against you... just a little weird.
Anyway, I would look at how much all the prices go for brand new, and low-ball them quite a bit until you can come up with some reliable numbers when put up against similar parts being sold on Ebay, The Boards, and any other auctions you can find.
I think that would be your best bet for getting rid of everything, and good luck with the swaps if that's what you plan on doing. Hate to see two f-bodys wrecked though .
We bought them both already wrecked- somebody else did the honors, and there were far from salvageable. got fair deals, just had to go through the work of stripping them & now selling off what's not needed. it's a longer route to the same end, hopefully it saves us a little money this way too... it's just more work
pics?
sorry that's the one thing i didn't do. i was in a rush to tear it down, get any good parts out, get the shell to the crusher, & take all i don't belive i need to the swap meet
the engine definitely has center-bolt valve covers, and it was titled as a 99.
we took the stuff to the fairgrounds today. we need to get rid of this stuff, the booth is full, stuff is piled up. i should have got 2 booths... oh well. come get it, i don't want to bring it home.
in transit some stuff got chewed up... the bumpers got scratched up pretty bad, and one radiator now has a broken tank... there's no telling what else got torn up.
what we sold-
99 car:
front calipers
cargo area cover
seatbelt loops that attach to headrest
maf boot/bellows
RF spindle/hub/C-Arms
headlights
wheels
96 car:
RR caliper/ebrake
fuze panel cover
rear axle
dash
console
e-brake lever
door switches
pending sale to Mikey 97Z M6:
driveshaft
steering rack
wish we'd sold more... prices got cheap.
99 car:
front calipers
cargo area cover
maf boot/bellows
headlights
wheels
96 car:
RR caliper/ebrake
fuze panel cover
rear axle
dash
console
e-brake lever
door switches
driveshaft
steering rack
Remember you are at a swapmeet people are there trying to talk down prices.
My husband ended up getting a set of Wheels & Tires for his 67 there the guy wanted $120 for the set of 4 but I talked him down to $100 ( would have sweet talked him down more if it sat there longer but husband saw them first thing in the morning)
I talked ot you there for a couple of minutes asking you about the bolts and such.
I know what you mean about the prices. It was irritating sometimes the ridiculous offers and lies people will tell you about prices they've seen and can get. I had $200 on a set of 17x9.5 ZR-1 wheels (rate them an 8 of 10) to fit a early C4. A guy told me he could buy them for $100 a pair elsewhere so that what he'd offer me. I told him he should buy em from the other guy then... lol
It was pretty tough to sell anything newer than 1970 for anything more than $150 or so. They just aren't getting the new stuff around there. Engines don't sell worth crap either. No one brings real money out (>$1000). My largest sale was a $600 one and it was to another vendor... on Sunday.
that was you about the bolts huh? i had no clue
let me know what you need, the buckets of bolts are down at my brother's place... i might have it.
I was real tempted to bring a big plastic tray, spread out all the nuts/bolts/ fasteners/misc & post a a price of a handful for a buck.
they seem to go for cheap stuff... the guy in the booth beside mine probly made $1000 on saturday alone, one of his kids probly made $200 just going around w/ the wagon & a 'for hire' sign. he was selling cheap used tools, some were really nice stuff too, and a few rusty crusty car parts.
