sega rally
11-24-2002, 09:56 AM
Why is it that you can delete skip shift with LS1 edit, but you cant delete TCS or ASR with it?
felton316
11-25-2002, 12:22 AM
Just go to TCS retard vs RPM at set all values to zero. That should effectivly get rid of ASR/TCS. Even if the light is on, it will only pull zero's. I wouldn't recommend it, it can be helpfull in rainy days. Just turn the switch off.
Predator
11-26-2002, 12:17 AM
Also, SLP sells a reverse module that defaults the TCS to off, at startup. If you want traction control on, you have to press the button.
