Custom T4 turbo bracket to mount to chassis
Figured I post alink here for those interested. It shows the turbo mounted in the fenderwell on the driver's side in front of the tire. You can mount it where ever you want.
https://ls1tech.com/forums/showthrea...56#post4223956
[I believe it is .5" thick mild steel (could be 3/8"...dont remember off the top of my head). It is tig welded and has provisions for 4 mountings spots. The flange has a T4 bolt pattern and the opening is a 2.5" hole (instead of the T4 shaped opening). Their is a short section of 2.5" pipe tig welded to the flange. All the welds were professionally tigged.
The picture shows a precision T76 housing bolted in for test fit. Figured I post alink here for those interested. It shows the turbo mounted in the fenderwell on the driver's side in front of the tire. You can mount it where ever you want.
$125 shipped...firm
$125 shipped...firm
