Misefire cylinder 7 HeLP!!
LS1Tech Administrator
Received 1,462 Likes
If a misfire on #7 is the only issue you're having, and you're 100% sure that the wire is on the plug and coil all the way, then I'd start by:
1) Swaping that wire with another plug and see if the issue moves with the wire
2) Trying another plug in #7 and see if it clears up
3) Try swaping the #7 coil with another coil and see if the issue moves
....in that order.....
Excellent advice
